12 Pages V  1 2 3 > »
> LED Front Turnsignal And Rear Brake/Taillight/Turnsignals
Spoke
post Jan 15 2015, 10:25 PM
Jerry
This is a group buy for front turnsignal bucket LED boards, rear tail/brake light LED boards, and rear turnsignal LED boards.
Please respond to this thread if you are interested. Purchase requests will be handled in order as they are recieved in this thread.
The only thing group buy of these boards are the bare PCBs. The boards are hand assembled one by one, tested and delivered as they are finished. I will not request payment until your PCBs are to be assembled. Time between payment and shipping should be about 2 weeks. This group buy will last several months so please be patient.
I will PM you when I am prepared to assemble your boards. If I PM you and your plans have changed, please let me know.
Front LED and rear LED boards will be shipped separately. Shipping for CONUS for front or rear LED boards is $10.
Now is a good time to seal up the front and rear buckets to protect your LED board investments.
I am very pleased to be able to offer bundle pricing for front and rear bucket and rear lens seals by 914Rubber for anyone purchasing front or rear LED boards.
Prices:
Front bucket seals: $12.50 savings of 24% over retail
Rear housing seals: $16.00 savings of 33% over retail
Rear lens beads: $5.00 savings of $28% over retail
Front Bucket Seal
Rear Housing Seal
Rear Lens Bead
Spoke
post Jan 15 2015, 10:28 PM
Jerry
The rear LED board is available in 3 different configurations:
1) Brake Light: RED LEDs: Price: $90/pair
2) Turnsignal: RED LEDs: Price: $90/pair
3) Turnsignal: AMBER LEDs: Price: $90/pair
Shipping:
CONUS: $10
Outside CONUS: Determined at purchase.
CONUS payment examples:
Brake LED only: $90 + $10 = $100
Brake LED and RED/AMBER Turnsignal LED: $180 + $10 = $190
Each pair includes:
o 2 PCBs
o Brake/Taillights: 56 RED LEDs
o Turnsignals:56 AMBER (Euro) or RED (US) LEDs - Rearward facing; 8 side-facing LEDs to replace the small side running light. Side LEDs are AMBER (Euro) or RED (US) to match taillight lens.
Electrical Connection:
o Brake: Pigtail with 1157 base to plug directly into existing bulb socket.
o Turnsignal: Pigtail with 1156 base (turnsignal) and 5007 base (small side light)
6 clips for each pair to mount the boards to existing taillight housing for plug-n-play installation.
6 screws per PCB pair for clips + 1 extra
1 piggyback spade connector per turnsignal PCB pair in case existing turnsignal flasher is replaced by EP36 LED flasher from your FLAPS.
1 year guarantee
Electrical Characteristics:
Brake/Turnsignal: 0.35A @ 14V (4.9 Watt) each PCB
Taillight: 0.06A @ 14V (0.8 Watt) each PCB
Example boards shown with early prototype brass clips. Clips are plastic for these boards.
Spoke
Jerry
The front bucket LED board is available in 3 different configurations:
1) US Version: All AMBER LEDs: $120/pair
2) Euro Version - No Blanking: WHITE LEDs in clear of lens; Rest AMBER LEDs: Price: $130/pair
3) Euro Version - w/Blanking: WHITE LEDs in clear of lens; Rest AMBER LEDs: Price: $140/pair
Shipping:
CONUS: $10
US Version: $120 + $10 = $130
Euro Version - No Blanking: $130 + $10 = $140
Euro Version - w/Blanking: $140 + $10 = $150
Each pair includes:
o 2 PCBs
o US Version: 69 AMBER LEDs.
o Euro Versions: 21 WHITE LEDS (Running lights) and 48 AMBER LEDs (Turnsignal).
Euro Version with optional blanking will turn off WHITE LEDs when turnsignal is engaged.
4 clips for each pair to mount the boards to existing front bucket housing for plug-n-play installation.
4 screws for clips + 1 extra
1 piggyback spade connector if existing turnsignal flasher is replaced by EP36 LED flasher from your FLAPS.
1 year guarantee
Electrical Characteristics US version:
Turnsignal: 0.39A @ 14V (5 Watt) each PCB
Running light: 0.07A @ 14V (1 Watt) each PCB
Example front LED board shown with only tools needed: large Philips screwdriver for lens screws and smaller Philips screwdriver for PCB mounting screw.
Spoke
post Jan 15 2015, 10:44 PM
Jerry
Installation of the rear LED boards.
For the brake/tailight PCB, 2 long straight clips go toward the inside of the car, one short clip on the outside of the car. Screw in screws so the clips are loose.
After removing the bulb and securing the LED bulb base, gently press in the board evenly side to side.
Once the board is seated, gently tighten screws until tight. Try not to overtighten.
For the turnsignal PCBs, screw in the 2 long clips with a bend on the side of the board with 2 holes. The side with one hole uses the largest clip mounted on the bottom of the board as shown. You can gently tighten the clips before mounting.
The clearance of the lens and the clips between the brake and turnsignal is very tight. Make sure the lens does not get caught on the clips. It should fit right between the clips.
Spoke
post Jan 15 2015, 11:00 PM
Jerry
Installation of the front turnsignal bucket LED boards.
There are 2 clips for each board. The small one goes in front the the long one on the rear.
Screw in the rear clip.
The small front clip mounts on the top of the board. These will be screwed in when I build the board. The bottom of the board will contact the bucket base to keep the board straight.
Here's the board ready for installation with the bulb base connected.
When installing the board, make sure the pigtail does not interfere with the rear clip.
Gently slide the board in. There are slots on either side of the board to clear the guides on the sides of the bucket.
Ready for the lens. The lens will hold the board in place. If you need to reposition the board, do not grab the LEDs as they will move. Use a paper clip or similar wire to pull the board out.
siverson
post Jan 16 2015, 12:11 AM
Group: Benefactors
I'll take a full set!
front: Brake Light: RED LEDs + Turnsignal: AMBER LEDs
rear: Euro Version - w/Blanking
Thanks!
-Steve
Firstcar
post Jan 16 2015, 02:05 AM
Obsessive amateur mechanic
Jerry,
I'll take a set of the front bucket LED board Euro Version - w/Blanking and a piggyback spade connector for the new relay! Thanks
-Scott
A&P Mech
post Jan 16 2015, 06:59 AM
I am in for a full set. I would like the US version for the front buckets as well as the rear brake light and turn signals.
Thanks,
Ray
griffindoug
post Jan 16 2015, 07:03 AM
Spoke,
I would like a set of the rear Red Brake, and amber turns with shipping for 190.00
Doug
peteyd
post Jan 16 2015, 07:12 AM
Please put me down for a front bucket LED board in the US Version
Thank you,
Pete
chads74
post Jan 16 2015, 07:16 AM
I am in for a front set option 3) Euro Version - w/Blanking: WHITE LEDs in clear of lens; Rest AMBER LEDs:
I remember seeing something about needing something additional to make the blinkers work if you have front and rear LEDs installed. Am I remembering correctly?
Steve Snyder
post Jan 16 2015, 07:21 AM
I would like a set of rear brake boards (just the brakes: $90 + shipping) and a set of front Euro turn signal boards with no blanking ($130 + shipping).
I do not need any seals, but thank you for making that option available.
Zimms
post Jan 16 2015, 07:47 AM
I am in for front turn signals, euro, non blanking
EdwardBlume
post Jan 16 2015, 08:24 AM
Cool. Very Cool. (IMG:style_emoticons/default/aktion035.gif)
post Jan 16 2015, 09:06 AM
I'm in for the following:
Front:
R_u_dd
post Jan 16 2015, 09:25 AM
I am interested in the Euro Front amber/white, so that I may use the front light as a white running light and turn signal. I have no side turn signals up front, so I need the blinking capability. Is that what blanking is? Please explain. So, yes put me down for a front end Euro configuration. Thanks
GermermanCarGuy
post Jan 16 2015, 10:09 AM
GermanCarGuy
Still in for:
Rear Brakes Lights (pr)
Rear Amber Turn Signals (pr)
and Front Euro w/blanking (pr)
Very excited. (IMG:style_emoticons/default/piratenanner.gif)
Please bundle with complete seal package (f/r) as advertised in your Posted Feb 5 2015, 08:59 PM post.
Still excited. (IMG:style_emoticons/default/piratenanner.gif)(IMG:style_emoticons/default/piratenanner.gif)
rnellums
post Jan 16 2015, 10:17 AM
Professional Enthusiast
Sign me up for a pair of the us front turn signals! I love my rears!
-Ross
StratPlayer
post Jan 16 2015, 10:21 AM
StratPlayer
I'm in for a set. Front Euro's....
post Jan 16 2015, 01:54 PM
Count me in for front/ rear euro type
1 Members: SO.O.C914er
- Lo-Fi Version Time is now: 20th May 2026 - 08:09 PM
