3 Pages V  1 2 3 >
> Chris Foley's Tangerine Racing shift linkage kit
Geezer914
post Jun 28 2012, 08:46 AM
Geezer914
I just finished installing Chris Foley's shift linkage kit. The car shifts smooth as silk like a normal car with a 5 speed. It's like night and day! There is no question what gear you are shifting into, the shifts are solid and tight. I first replaced all the bushings using the stock shifter. It was like "what gear am I going to find now?" It would grind going into 1st and my arm was hurting from pushing the shifter as hard as I could to the right to find 4th and 5th, and when shifting into 5th, finding 3rd instead! So I installed a Renn shifter, a little better, but not much. Was not happy. So I sprung for Chris's linkage kit and firewall bearing kit. The car is a pleasure to drive. Thanks Chris for a super engineering job and a high quality kit. If you are not happy with the way your car is shifting, I would highly recommend installing this kit. (IMG:style_emoticons/default/smilie_pokal.gif)
post Jun 28 2012, 09:01 AM
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif)
moggy
post Jun 28 2012, 12:23 PM
I see no advantage over the Rennshift kit with that. Good to have an alternative I agree. But if your Rennshift like for like kit wasn't working, which looks exactly the same, then I would be asking myself whether it was installed and setup correctly in the first place.
post Jun 28 2012, 12:54 PM
QUOTE(moggy @ Jun 28 2012, 11:23 AM) *
Good afternoon, to the best of my knowledge the Rennshift linkage kit is NO LONGER available. That being said, Mr Foleys linkage set-up is 'The Only Game In Town'.
dadaDaveed
post Jun 28 2012, 01:03 PM
QUOTE(moggy @ Jun 28 2012, 01:23 PM) *
I believe he was referring to just the Renn Shifter... not the linkage that James used to sell.
JRust
post Jun 28 2012, 01:57 PM
QUOTE(dadaDaveed @ Jun 28 2012, 12:03 PM) *
seanery
post Jun 28 2012, 06:01 PM
waiting to rebuild whitey!
Group: Retired Admin
The shifter and the linkage kit are apples and oranges.
EdwardBlume
post Jun 28 2012, 06:41 PM
QUOTE(76-914 @ Jun 28 2012, 08:01 AM) *
but I'm pretty sure its mostly a long straight bar...
FWIW my Rennshaft linkage popped off at the last autocross. Ended up back by the wheels. Maybe that's why its not made any more.... but the Rennshift a damn great shifter...
ChrisFoley
post Jun 28 2012, 08:19 PM
I am Tangerine Racing
QUOTE(RobW @ Jun 28 2012, 07:41 PM) *
In the case of a -4, the bar has 3 bends. (IMG:style_emoticons/default/biggrin.gif)
My shift linkage kits are not a fabrication project as the JWest kits were.
The kits are delivered ready to install, with a powdercoated shift rod that has permanently installed u-joint(s).
However, installation does require modification of the sideshift console.
JWest
post Jun 28 2012, 10:02 PM
Properly installed it can't pop off any more than your steering can come apart - if the bolts are put in the grooves on the u-joints then a bolt has to fall out for the linkage to come apart. The splined end may not have been installed far enough and tightening the bolt worked to squeeze the end out instead of capturing it.
When Porsche quit making the rear cover I chose to end my production. I didn't like the idea of a precision linkage under the car without boots and covers, and it was already too expensive without considering making that part myself.
The RennShift shifter will not be a big improvement with worn out linkage and bushings. The tighter the linkage, the greater the gain, and Chris's solution is the best out there.
These parts work together - the shifter changes the dynamics (helps find the right gear without overstiff springs) and removes friction and slop in the shifter area. The Tangerine linkage tightens up the supports without adding binding that can happen if the bushings are made tighter with stock linkage.
post Jul 14 2019, 08:22 PM
QUOTE
After 7 years, how's it working ? Any suggestions for someone anticipating this project
post Jul 14 2019, 09:25 PM
Shifting in a 914 is a system, only as good as it's weakest part. Think of the shifting in 3 parts; shifter, linkage, transmission. Jwest for the shifter. From the shifter to the trans, replace everything you can with Tangerine racing linkage and bushing, then make sure your trans is rebuilt to spec. It's not cheap but to get the best shifting possible, this is the formula.
Larmo63
post Jul 14 2019, 10:38 PM
Ask Keith, @914Toy
He has done both of these mods and swears by them.
I hope he comments here.
VaccaRabite
post Jul 15 2019, 06:19 AM
En Garde!
I have a Rennshift and one of Chris's kits in my car. I really like that combo.
It was touchy to get adjusted properly, but the car shifts way easier now. Night and day different.
Zach
post Jul 15 2019, 06:22 AM
QUOTE(VaccaRabite @ Jul 15 2019, 05:19 AM) *
Zach
Thanks. Did the installation go as planned or are some unanticipated things to watch out for.
gereed75
post Jul 15 2019, 06:25 AM
I have a Weltmiester short shift shifter. It simply provides a longer lever arm to actuate the shift rod.
I have a Tangerine bushing and the kit at the rear that includes a shift shaft and the two bushings at the console. These components translate all of the shift rod motion into precise rotation and linear travel that is required to most efficiently operate the shift mechanism.
The car shifts pretty well, way better than stock where the end of the shift rod is essentially wagging around rather than rotating and sliding.
This so much increases the pleasure of driving these cars. Gives it a much more precise feel. Get one!
post Jul 15 2019, 06:32 AM
On my 3.2 conversion, I have a jwest shifter, full jwest linkage kit and dr evil rebuilt trans. The car shifts like a bolt action rifle. Smooth and positive. Pretty awesome on a 914.
I have a stock tailshifter on my 1.7 car. I learned to shift on a loose tailshifter when I was 16, so for me, it's doable but it's night and day.
post Jul 15 2019, 06:38 AM
Hi Mark- That is the exact set-up I have for my car. I hope it works as well as I envision. (IMG:style_emoticons/default/beerchug.gif)
post Jul 15 2019, 06:51 AM
I almost forgot - Zach's handmade shift knob. Icing on the cake. (IMG:style_emoticons/default/beerchug.gif)
914Toy
post Jul 15 2019, 09:06 AM
QUOTE(Larmo63 @ Jul 14 2019, 09:38 PM) *
Ask Keith, @914Toy
An excellent and relatively easy upgrade, and one that is obvious each time you drive your car.
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 19th May 2026 - 12:06 AM
