> what did you do to your 914 today
mrbubblehead
post Dec 17 2011, 08:07 PM
Twodollardoug
i just wanted to start a thread to see what you guys do day to day on your cars.
i'll start,
about a month ago, i pulled my engine and trans to put in a new clutch. had the flywheel lightened and resurfaced. but what i didnt know is that i had to shim the little ball that the clutch arm rides on, after a resurfacing. so guess what i did today?
yup, pulled the trans and put an extra washer under the ball. you have to goop up both washers to get it to seal because the threaded hole goes all the way thru to the inside of the trans. i also replaced the plastic cup that the ball rides in. the throwout bearing and its little plastic blocks were fine so i buttoned every thing back up. 5 hours total. i think this has been the cheapest repair yet on my car. $2.75 for the little plastic cup.
what did you do to your 914 today?
907 Pages V  1 2 3 > »
Replies(1 - 19)
racerbvd
post Dec 17 2011, 08:17 PM
I put a magetic wood dash kit on the dide (IMG:style_emoticons/default/shades.gif)
ellisor3
post Dec 17 2011, 08:20 PM
HPWhore
I put a new fan belt on my 3.2. What a suck fest. No way to get both hands near the pulley. When I was done my arms felt like Stretch Armstrong.
shuie
post Dec 17 2011, 08:25 PM
(IMG:style_emoticons/default/sawzall-smiley.gif)
cut out my floors
windforfun
post Dec 17 2011, 08:29 PM
Q-tipped its ears.
Gustl
post Dec 18 2011, 12:27 AM
914 enthusiast & historian
Region Association: Austria
yesterday I put my original leather steering wheel out of the car and replaced it with a newly leather covered one on a 30 mm longer hub (that gives me more leg space; I'm 6 ft 3")
today I will put out the "very custom" permatune installation out of the car and replace it with the original and newly rebuilt Bosch HKZ
after this I will set the car in hibernation mode (IMG:style_emoticons/default/biggrin.gif)
gendent
post Dec 18 2011, 12:51 AM
I drove it to Costco, and back. Usually a 15 minute drive turned into 90 minutes. The long way home. No repairs. No break down. All back roads and no traffic. I did once worry I should be doing something else, but I got over that. Maybe tomorrow I will actually repair something.
Bob L.
post Dec 18 2011, 12:53 AM
I put the bumperetts back on the front and began removing the fuel system for cleaning.
Gendent: Sounds like a thorough test drive and shake down. you should be proud. (IMG:style_emoticons/default/biggrin.gif)
PancakePorsche
post Dec 18 2011, 01:29 AM
Welded in Autopower roll cage, installed repainted fuel tank. Ready for track in two more weeks !!
cwpeden
post Dec 18 2011, 01:42 AM
Great White North, huh?
Started it, wamred it up, turned it off. Then wished I had more time to fix the brakes.
Dumped half the res. of brake fluid on the floor of the carport for no apparent reason. Right off the master cylinder. Figure its the stupid hard lines from the res. They were a !@#!@ to get in.....or was it just me?
infraredcalvin
post Dec 18 2011, 02:12 AM
Distracted Member
QUOTE(PancakePorsche @ Dec 17 2011, 11:29 PM) *
Would you mind starting a thread with pics on this one? I have a stable energies bolt in cage that I have an idea how it goes in, but would like to see others' solutions.
Sorry to hijack, back to the topic... I went to the shop and wished my baby a merry Xmas, hopefully Santa will bring some tools (a welder) so I can start spending some quality time again...
etcmss
post Dec 18 2011, 06:06 AM
etcmss
Prep the front suspension for removal..down to the last 2 bolts. out it comes
bulitt
post Dec 18 2011, 06:43 AM
Achtzylinder
Picked up a fresh 327 SBC from a Nascar Mechanic. Xmas present for my 914.
Bored .060 over = 338 c.i. @ 330hp, Hi rev cam, roller rockers, etc. !
Phoenix-MN
post Dec 18 2011, 12:01 PM
No words needed (IMG:style_emoticons/default/shades.gif) and yes, it's cold in the garage...
914itis
post Dec 18 2011, 12:07 PM
I started to reassemble the engine. Installing the thins , cleaned fan shroud
BuddyV
post Dec 18 2011, 12:50 PM
Robert
I replaced my 180 rear springs with 140s yesterday.
gary gartner
post Dec 18 2011, 12:54 PM
i know more than a newbie---way less than a guru
I will dust him off, clean up and get reaady for the SoCal Hangover run
That is all Folks
Gary (IMG:style_emoticons/default/beerchug.gif)
MrHyde
post Dec 18 2011, 01:25 PM
Finished welding a few touchups on the rear floor pan top-side..
Welded in the Tangerine racing rear inner suspension ear reinforcements.. Then ground the welds and rattle-can primer.
Then started taking apart one of the trailing arms.. got the calliper, rotor, shock/spring, dust shield off. Then started looking on here for an easier way to get the hub and bearing out.
Next I have to deep fry a turkey for about 8-10 people tonight.
Oh.. and it snowed a bit.... not enough to break out my snowboard, but its starting to feel like Christmas
mrbubblehead
post Dec 18 2011, 01:45 PM
Twodollardoug
nothing.....its raining....ARGH! (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/hissyfit.gif)
stugray
post Dec 18 2011, 02:13 PM
Finished cleaning the last of my parts fro my Dual Weber rebuild in the ultra-sonic parts washer.
Touching up roll cage & reinstall after all new interior.
Replaced seat rails with race adjustable & grade 8 bolts.
Stripped & repainted the hellhole from PO's silicone mess.
Repainting the rear firewall engine side.
23 User(s) are reading this topic (23 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 16th September 2026 - 11:48 PM
